MidProd 500 Single
Re: MidProd 500 Single
Postby BrianL » Sat Dec 29, 2012 9:42 am
And my front tire, race compound Avon...We gonna have some FUN in 2013!!! :twisted: :twisted: :twisted:
We don't stop ridding cause we get older,
We get older cause we stop ridding...
Special thanks to St-Hubert Machine Shop and Built by Bill
BrianL
Postby Pearson » Sat Dec 29, 2012 11:09 am
I like the "go fast light weight cardboard number plates" :lol:
Looking forward to seeing the bike come alive on the track!
Cheers Brian
Carl
Pearson
Postby TimV » Sat Dec 29, 2012 11:22 am
I'm not sure the red ratcheting strap will provide much help as a steering damper, but the rest is coming along nicely!
8)
Tim Voyer #840
CMR Suzuki TR750 Replica
CMR-Seeley 350 Replica
1971 P1 CB350
Whatever you do, always give 100%. Unless you're donating blood.
TimV
Postby pacomotorstuff » Sat Dec 29, 2012 1:07 pm
Looking good!
Those aren't cardboard, its a special composite material! Very, very lightweight! But what class has brown number plates and black numbers?
Pat
Postby John Crossley » Sat Dec 29, 2012 5:31 pm
TimV wrote:I'm not sure the red ratcheting strap will provide much help as a steering damper, but the rest is coming along nicely!
8)
I'ts going in the new rulebook, we all have to run red ratchet straps, steering dampers are outlawed. :shock:
John Crossley
John Crossley
Postby BrianL » Sat Dec 29, 2012 5:38 pm
The ratchet strap came straight from Ohlins and cardboard is the new plastic...What, are you guys, like, vintage racers or something..... :lol: :lol: :lol: :lol: :shock:
Does the carb go under the seat, cause it's not giving me much more power where it is......??? :?
BrianL
Postby BrianL » Mon Dec 31, 2012 8:38 am
Left the TT for a bit in order to get to the SR head. This puppy sat with the decompression release jammed open...Piston seized and loads of rust in the port. I want to use this head on the TT as the SR came with bigger valves and is a common mod for the TT. Springs are within spec, guides too. The whole thing is cleaning up nice. I'll run it over to JPrecision and have the experts offer their opinion on the seats and valves, but it all looks good. For the street, I'd run it as is, but since it's apart and will be spanked :twisted: at the track, I'll let the boys decide. They can massage the ports while they have it... :lol: Cheers.
BrianL
Postby Dewey » Tue Jan 01, 2013 12:25 am
If I were you, at this point depending on how deep your pockets are for fuel, check with Link or the machinist to see how much can be milled off the head. My .02
Postby BrianL » Tue Jan 01, 2013 12:59 pm
Thanks. Already got the specs from many different sources. Kinda have a good idea where I'm heading with the head...(get it? heading with the head... :lol: ). Have to keep compression in the reasonable range for kick starting. 10.5 to 1 seems to be a good ceiling for many racers still using their kick starters...Am in touch with Linc every week, I bow to the Master!!!!!! :twisted:
BrianL
Postby Dewey » Wed Jan 02, 2013 3:50 pm
Something to aim for...
From Mosport 2011
Postby BrianL » Wed Jan 02, 2013 9:26 pm
Yes, the Master!!!! Check out this build...
The entire link is here...Really something and Swantz too...Cheers.
http://seeleynorton.com
BrianL
Postby BrianL » Thu Jan 03, 2013 8:29 pm
Nice to see a 40+ year old rim come back to life. Alum. polish, elbow grease, grinder, bead blast and now it almost looks new...
BrianL
Postby BrianL » Thu Jan 03, 2013 8:30 pm
And my shifter seems to be all ready to go....
BrianL
Postby BrianL » Mon Jan 07, 2013 11:41 pm
Work continues...Steering damper sorted and installed, rearsets welded (Ugly!!!), shift linkage sorted and intalled, rear brake pedal cut, welded and installed, rear shocks cleaned up, bellypan on the way, alum. marked and started to cut, but jigsaw ran out of juice (recharging battery). Front end is on the way so front wheel can slip right in. Been drilling for safety wire, almost finished that too. Will be very close to teardown for grinding and painting the frame. Friend moved away with my rivet gun, so bought a cheapy at CT....Cheers, Brian.
BrianL
Postby BrianL » Mon Jan 07, 2013 11:44 pm
All in all, a good couple of days.... :twisted: :twisted: :twisted:
BrianL
