Board index VRRA Racing Forum Trading Post - Bikes for sale!
Sold - P2, Whittaker Frame, BMW R75 engine
This section is for bikes only
Postby everyman07 » Tue Nov 12, 2024 1:44 pm
Sold - I wish this had gone to someone in the VRRA/Canada.
It feels wrong for this set up to not be raced. I'm dropping the price and taking a little hit to get someone out on the track.
All these parts are new/unraced.
$12,500 usd (was $14k)
Sorry to say life changes (good ones) have put an end to my racing plans. Was really looking forward to racing with the VRRA.
Wanted to offer this to you folks first.
2023 Paul Whittaker Frame
- Uncut, unmodified
– Receipt from Paul included
- Full bodywork from Paul’s molds
- Gas tank in sidecar fender
1972 BMW R75 engine
– 1500 miles
- 37/11 final drive
- Full reseal
- New rings, hone
- New clutch fiber disc, R90 spring
- Drilled, balanced flywheel
- Extended oil tube, cap for oil cooler
- Oil cavitation plate
Equipment
- New Mikuni VM34 carbs jetted for engine
Slide – 2.5
Needle – 60 H4
Main jet – 170, 180
Pilot – 35
Float needle – 1.5
Spray tube – (159) P-5
- Uni pod filters
- Buchannon 16” steel rear rim, custom spokes
- New Ferodo rear brake pads, springs (installed)
- Harley front wheel, Suzuki Caliper, 14.8 mm brake MC
- (2) new Dunlop RS2 350-16 tires
- Mini sidecar wheel, hydraulic brake setup
- New Camac 145R10 sidecar tire
- (4) new Hagon shocks
- Wilwood brake proportioning valve
- 3” extended spacer (trans to final drive) Brian Phillips
- TC Bros exhaust pipe kit (not welded), includes 2 to 1 y-pipe
- Supertrapp muffler
- Magura quick turn throttle
- Martek ignition
- New BMW clutch cable
- Plywood and foam decking (cut) for sidecar platform
- Electric fuel pump
- BMW RGS oil cooler
- VW (Sachs) Beetle steering damper
Some Assembly Required
Videos of build progress available at https://www.hellbendersracing.com/racing/media.html
Located in Marysville PA.
$14000 USD
You can contact me at everyman07@gmail.com or through the board's message function
everyman07
Return to Trading Post - Bikes for sale!
