AHRMA at NJMP Sidecars Aug 2-4 2013
Postby Kyler » Wed Nov 07, 2012 9:41 am
AHRMA is racing at New Jersey Motorsports Park Aug 2-4 2013. I have confirmed with AHRMA that sidecars will be racing.
I encourage VRRA to add it to their schedule or at least give it a strong push. This represents a terrific opportunity to give more exposure to sidecar racing and attract more racers.
I'll be there with my P3 for sure!
Ken Kyler
- '11 CSR P3 Sidecar w/ Suzuki GS1100 (#375)
Kyler
Re: AHRMA at NJMP Sidecars Aug 2-4 2013
Postby paul whittaker » Wed Nov 07, 2012 7:02 pm
will the new P3 class (1300cc any configuration) run with P1-P2? Where else can these bikes race?
Postby Kyler » Wed Nov 07, 2012 7:28 pm
paul whittaker wrote:will the new P3 class (1300cc any configuration) run with P1-P2? Where else can these bikes race?
They can run only in AHRMA races. I don't know of anyone with one or with plans to build one. You can count the number of P3s in the east on one hand, if I recall correctly. AHRMA does run the P3s with the P1 & P2 bikes.
Ken Kyler
Kyler
Postby Kyler » Thu Nov 08, 2012 1:34 pm
here's the full text of the new AHRMA rules
P1—Two-strokes up to 1967, maximum 500cc, plus allowable overbores. Four-strokes up to 1974, maximum 750cc, plus allowable overbores. Single- or two-cylinder engines with no more than two valves per cylinder.
P2-—Four-strokes up to 1982, up to 750cc, maximum two-valve-per-cylinder twins.
P3—Four-strokes up to 1982, 750-1300 cc any configuration.
Ken Kyler
Kyler
Postby tintop » Thu Nov 08, 2012 4:33 pm
Kind of a cockup set of engine rules. With the 74 cut-off for P1 the two main engine choices would be BMW & Yamaha XS (with 750 kit). As those are the same dominate engines choices for their P2, kind of kills off P1, given similar wheel & tire rules. :(
My .02, a better version would have been:
P1 - 500cc 4 strokes, single or twin, sitter, or kneeler frame, 16" wheel, 67 cut-off
P2 - 500 2 stroke twins (cut-off??)/ 750 4 stroke twins (max 8 valves, allows Weslake / Nourish head Triumph), 15" wheel min. / 5" tread, 74 cut-off (allows electric start XS 447 cases)
P3 - 4 stroke 750, max 4 cylinder, minimum 10" wheel / treaded tire (max 6" tread??), 74 cut-off (allows Trident 3, and Honda SOHC, and period frame designs like 10" Windle)
P4 - 4 stroke 1000cc, any cylinder configuration, minimum 13" wheel / slicks (max 8" tread??), 82 cut-off (allows Z1, CB900F, CBX, GPZ, others??).
Postby Kyler » Thu Nov 08, 2012 5:55 pm
P4 should have a later cutoff - lets at least get into the oil-cooled era!
Ken Kyler
Kyler
Postby MGill » Thu Nov 08, 2012 7:41 pm
For god sake please don't try to change our rules.
Just because they screwed it up is no reason for us to
follow.
Not sure how or why this affects VRRA
follow.
Or USCRA Or SRA for that matter...
Postby MGill » Thu Nov 08, 2012 7:46 pm
USCRA has their vintage festival that weekend
Postby Kyler » Thu Nov 08, 2012 8:29 pm
mgill wrote:For god sake please don't try to change our rules.
follow.
I'm not trying to change anything. Just sharing what I found.
Ken Kyler
Kyler
Postby chairman » Thu Nov 08, 2012 8:49 pm
AHRMA, LOST IN THE WIDERNESS
chairman
Postby tintop » Thu Nov 08, 2012 8:53 pm
follow.
Doesn't affect us at all (P2), was just an observation, and an example of how it could have been better. Don't get your nickers in a knot. :D :D
That said, there is a valid argument to be made that our current P3 could be divided into Classic & Post Classic, like P1 & P2 are Vintage & Super Vintage. Whether that would encourage greater participation in P3 is open for debate.
Oh and Kyler, if you think moving the 'yard sticks' to allow the oil cooled GSXR would be a good idea, I'll see your move with that liquid cooled VF750F I have. So no I wouldn't support a later cut-off, just a re think of P3. As it stands, all the sidecars run together in VRRA. So if I wanted to get some seat time with my P3 Fiddaman, it would get an engine that allowed me to run SRA & AHRMA events.
Postby Kyler » Thu Nov 08, 2012 9:11 pm
I'm just happy to be racing. :mrgreen:
As a FNG, I'll be smelling the exhaust of the pack for a long time. :wink:
Everyone can change the rules all they want, I'll stick with my rig and the GS750 motors as long as my skill is the limiting factor :lol:
Ken Kyler
Kyler
Postby MGill » Fri Nov 09, 2012 4:03 am
My knickers are not in a knot,
at least they weren't until you used those f---* smiley faces.
The USCRA has an event on this weekend in August
and has in the past been a great supporter of
the VRRA and vice versa, I'd rather support them by going to NH and see
they would make the effort to come up to Mosport and support us.
Postby tintop » Fri Nov 09, 2012 10:28 am
The USCRA event in May is on my calander for 2013. I would also consider the Aug, and September ones, baring conflict with VRRA (and a healthy bike, and bank account). That said, USCRA only run P1 & P2 using rules that match ours (no P3), and SRA don't run Vintage (per say :wink: ).
This banter was really about AHRMS's change to their P3 rules. If the solo guy's can discuss adding a pure GP class, making rules exceptions for some bikes to beef up P3M & H, and eventually add P5, why should discussing P3 sidecar be off limits??? It's not like this effects some huge group. We had x1 P3 at the TT, and x1 at the Classic.
Next
