http://ontario.kijiji.ca/c-cars-vehicle ... Z304095847
Fame and fortune await you!
pz1morton wrote:Steve did you get that little pinky stuck somewhere it should not have been?Regards Paul
Little Red wrote:Was the reason you did not let go of the handle bar is that you thought you could still save the Harley while sliding through Moss's corner? We all know your good, but not sure if your that goodHeal quickly and maybe I will see you at the College one of these weekends.
BTW-That's one wicked Harley, 520 pounds, 88hps, questionable race frame(great road bike) and no slippery bodywork = 1.31s at Mosport for those guys at the front, explain that to me!
Jim Kots wrote:BTW-That's one wicked Harley, 520 pounds, 88hps, questionable race frame(great road bike) and no slippery bodywork = 1.31s at Mosport for those guys at the front, explain that to me!
Crevier has won his share of cups, did they actually run those bikes over a scale and dyno after the race?
Looks like the suspension counts, and trying to lighten something spinny in the engine by 8 lbs, it will spin up quicker but shouldn't affect HP.
From CSBK site:
HORSEPOWER LIMITS
For the XR1200 class, each machine may develop no more than 92 hp at the conclusion of the event.
WEIGHT LIMITS
XR1200 machines must weigh no less than 512 pounds in the same condition in which they finish the race, including all fluids such as oil, water and fuel. Weights will be checked immediately following races, and no fluid may be added prior to the determination of weight or horsepower check on the Dyno.
Users browsing this forum: No registered users and 6 guests
