Board index VRRA Racing Forum Trading Post - Parts & Accessories
Looking for CB350 Parts
Items for sale, wanted to buy, trade,
Postby Brian Stevenson » Sat Sep 20, 2025 4:56 pm
Looking for some parts to rebuild a CB350... I know its a bit of a long shot but...
1) Frame and swingarm, it must be solid. Normally the bottom frame rails are rotted out on every one. Its a very bad design
2) Rear Wheel. I really only need the hub as it looks like something got jammed in the spokes and ripped them through the hub. Must have a good drum
3) Excel (or similar) 18x2.15 rim drilled for 36 spoke drum
3) CB350 Rear Brake Rod
4) Complete CB350 Motor (68-72)
5) CB350 Gas Tank, clean inside
6) RZ350/RD350YPVS Triple Tree - Top and Bottom (83-91 but would prefer 83-85 as they are stronger)
7) ZX10r or ZX6R on/off/starter switch that mounts to the right handlebar
8. Domino Twin Pull Throttle (part number 1335.03)
9) One Mikuni VM30
10) One DynaTek Coil - Black, Single Output, 5 ohm
11) Suzuki non electronic GSXR 600, 750 or 1000 steering damper, the little one that sits in between the forks.
12) Scitsu Tach with brown wire (A programmable Scitsu will not work, it still needs to be the old brown wire if you are running it off the cam)
The rear tire has rubbed on the other bike as the wall has worn through. I will be getting a new set of 3CR Contis from Two Tyres in the UK in March. They are always fresh as the last 2 sets I got from them were made the same year I bought them. Happy to split shipping if you need a set.
Re: Looking for CB350 Parts
Postby pacomotorstuff » Sun Sep 21, 2025 7:48 am
Brian, sent you an email.
Regards,
Pat Cowan
Return to Trading Post - Parts & Accessories
