Ope665 wrote:I can’t seem to find a definitive answer or direction on drilling and safety wiring. So here are my questions to you folks:
What size holes should I drill to do the safety wiring?
What size wire do you use?
Best place to get safety wiring pliers?
Thank you
Lee
Lee, FYI. I copied and edited this from my copy of the 28th edition of Machinery's Handbook.
Lock Wire Detail.
Wire ties are frequently used as a locking device for bolted connections to prevent loosening due to vibration and loading conditions, or Tampering.
No more than three (3) bolts may be tied together;
Lock wire must fill a minimum of 75% of the drilled hole provided for the use of lock wire;
Lock wire must be aircraft quality stainless steel of 0.508 mm (0.020 inch) diameter, 0.8128 mm (0.032 inch)
diameter, or 1.067 mm (0.042 inch) diameter.
Diameter of lock wire is determined by the thread size of the fastener to be safe-tied.
a) Thread sizes of 6 mm (0.25 inch) and smaller use 0.508 mm (0.020 inch) wire;
b) Thread sizes of 6 mm (0.25 inch) to 12 mm (0.5 inch) use 0.8128 mm (0.032 inch) wire;
c) Thread sizes > 12 mm (0.5 inch) use 1.067 mm (0.042 inch) wire;
d) The larger wire may be used in smaller bolts in cases of convenience, but smaller wire must not be used in larger fastener sizes.
Hope this helps.
