Two two strokes
Re: Two two strokes
Postby Bruce Mc » Sun Nov 12, 2017 7:53 am
Funny thing about the front fender. For some reason it didn't go with the chassis when it was sold. I have been dragging it around with all my worldly possesions for the last 30 years and no intensions to get back into biking. Also have a good friend I used to race F2 with that had a box full of TZ stuff he had been dragging around that he has donated to the project. I hope he takes my offer to use my Gixxer for the school this spring.
Bruce Mc
Re: Two two strokes
Postby Bruce Mc » Tue Nov 28, 2017 11:40 am
Waiting for parts so I get to cleaning up components. Someone did a great job making these silencers which are obviously not stock.
Bruce Mc
Re: Two two strokes
Postby Bruce Mc » Thu May 03, 2018 7:21 am
Project is moving slowly but forward. Finished off the rear brake and added a lot of small bits which have been a pain to source. Things like axle spacers, chain pulls, caliper seal kits, damper bracket and others have all come from overseas. These were recommended on TZ350.com, anyone have experience with them before I go ahead with the rebuild. Not sure I like the hollow crank pins.
Bruce Mc
Re: Two two strokes
Postby Bruce Mc » Thu May 03, 2018 7:38 am
Could use some help with front axle spacers, if someone has some time when changing tires to measure these they would be easy to machine. Left and right are the same size.
Also I have an Aeroquip brake line that I would like to use which has a British pipe thread (1/8 conical) which would need an adapter to thread into the Yam caliper (10X1.0mm)
Bruce Mc
Re: Two two strokes
Postby Justind97 » Thu May 03, 2018 7:59 am
Try Freco Fluid Power for the adapter. Near Hunt Club and Prince of Wales.
The random stuff they have there is awesome.
Re: Two two strokes
Postby bitzz » Thu May 03, 2018 10:46 am
There is nothing wrong with the ProX rods, don't use the bearings.
There is a Yamaha rod, 34X-11651-00, from an Exciter snowmobile, same dimensions.
Big end use Suzuki RM125 silvered:
Suzuki:09263-22060
Wiseco: B1047
ProX: 22-22816F
I prefer the hollow pin, IF the fit is still tight, like it still takes 5 tons to press out, and goes BANG when it releases in the press.
The solid serrated pin came with the RDs that had a great big alternator rotor hanging off one end of the crank.
I'll trade you solid pins for hollow ones.
Re: Two two strokes
Postby Bruce Mc » Sun Jan 27, 2019 1:05 pm
bitzz wrote:There is nothing wrong with the ProX rods, don't use the bearings.
Suzuki:09263-22060
Wiseco: B1047
ProX: 22-22816F
Can you explain your preference for the hollow pins?
Bruce Mc
Re: Two two strokes
Postby bitzz » Sun Jan 27, 2019 4:56 pm
They're considerably lighter
Re: Two two strokes
Postby Bruce Mc » Fri Mar 19, 2021 7:54 am
This has been a long haul but getting closer all the time. Hope to see the track this year.
Bruce Mc
Re: Two two strokes
Postby bwaller » Sun Mar 21, 2021 6:06 pm
Hope to see you racing it.
Which way'd they go?
bwaller
Re: Two two strokes
Postby Bruce Mc » Tue Mar 30, 2021 12:46 pm
Bruce Mc
Re: Two two strokes
Postby bwaller » Sun Apr 11, 2021 6:17 pm
What a great bike.
bwaller
Re: Two two strokes
Postby Bert Lilley » Mon May 29, 2023 5:18 pm
Woooooow wow suck,Blow Bang
Bert Lilley
Users browsing this forum: No registered users and 6 guests
