Project Belly Pan...
Postby Peter Balfour » Mon Apr 11, 2011 12:40 pm
OK, I finally decided I better figure out how to make a belly pan for my BSA B50 race bike. I know we are all faced with this project, some bikes will be a snap and others are going to take some major fabrication. I was lucky to talk to Kim Anderson not long ago and he gave me the idea to use a wax mold sheet. This stuff is great, molds easily around things and easy to piece togther with a simple glue gun. Here are a few images of the forming process.
Here is a frontal view, I also used some structural form to make the dams.
I obviously have to wrap my exhaust as its does go through this area but should not be a problem as the wax gives some space around things. I hope to glass this thing up shortly and see how it turns out.
Peter
#2
'71 BSA B50 P1-500
‘84 Yamaha FJ600
Peter Balfour
Re: Project Belly Pan...
Postby Colin Duncan » Mon Apr 11, 2011 2:21 pm
Hi Peter,
Looks good so far. Think I’m going to have too use a similar technique.
Could you please provide a little more info on the wax sheets?
Where you get it etc.
Thanks,
Colin
Better to bodge and ride, than polish and hide!
Colin Duncan
VRRA Executive
Postby Peter Balfour » Wed Apr 13, 2011 8:56 am
Using that wax sheeting is really the easiest way to get around compound curves. Kim got back to me and you can buy the stuff at:
http://compositescanada.com/
905-629-3178
Peter
#2
'71 BSA B50 P1-500
‘84 Yamaha FJ600
Peter Balfour
Postby pacomotorstuff » Wed Apr 13, 2011 4:24 pm
Ya, but you have to buy it a box at a time...
I've been using the stuff on and off for about 30 years now - its original use was in foundry pattern making, which I used to do years ago...
Comes in a lot of different thicknesses, with and without an adhesive backing. Fillets in different radii are available as well. I believe there are low and high temperature versions, depending on your use. I've always found it worked better with epoxy resins as the styrene solvent in polyester / vinylester resins sometimes softens the wax unacceptably.
If you aren't in the GTA and still want to try some, look for a foundry pattern makers supply house in your area - they should be able to get some.
Pat Cowan,
Pacomotorstuff
Postby Colin Duncan » Thu Apr 14, 2011 7:22 am
Thanks Gents.
Colin Duncan
VRRA Executive
Postby TimV » Thu Apr 14, 2011 9:20 am
Wax paper(steal it from the kitchen) works in a pinch too. Probably not as easy to use, but it works for me for the little bit of f/g'ing I do.
FWIW,
Tim
Tim Voyer #840
CMR Suzuki TR750 Replica
CMR-Seeley 350 Replica
1971 P1 CB350
TimV
Postby Peter Balfour » Mon Apr 18, 2011 9:05 am
The wax sheeting is cheap and easy to form unlike foam or cardboard. I just glassed my pan this weekend and this stuff works like a charm!
Peter
#2
'71 BSA B50 P1-500
‘84 Yamaha FJ600
Peter Balfour
Postby Peter Balfour » Mon Apr 18, 2011 8:00 pm
The pan is now glassed with the wax sheeting removed. That big clump on the lift is what is left of the wax sheeting once removed.
The wax sheet leaves a very uniform shape. I used structural foam on the end dams which will need to be glassed on the inside. This was an easy process and I would recommend this method. Now, I just need to smooth things out a bit and shoot it with paint and we're good to go!
Peter
#2
'71 BSA B50 P1-500
‘84 Yamaha FJ600
Peter Balfour
Postby Dave M » Thu Apr 21, 2011 4:23 am
Great tutorial Peter and the bellypan turned out quite good by the look of it.
Dave M
Postby thelittleguy » Sun Apr 24, 2011 9:10 am
Didnt know you was a patternmaker Pat, I still am, though I have made more models than patterns these last few yrs.Used to make patterns for Hailey industries for dehavilland turbo props yrs ago.
Thats when my job was interesting.Bloody CNC!!!!!!!!!!
Steve
thelittleguy
Postby pacomotorstuff » Wed Apr 27, 2011 3:31 pm
Oh ya,
Worked at damned near anything to put myself through university (BSc Metallurgy and Materials Science). One of those odd things; I was renting some space in a shop to build dirt track fiberglass parts to keep me in school and riding at the same time (will I ever learn?).
There was still excess space, so a small time mould and pattern maker rented it (he was ex-GM St. Catherines). He saw me reverse engineer a side cover for my girlfriend's YJ60 and hired me on the spot. First job - with his help - was building the foundry patterns for a B&D industrial table saw. Ever since then, I've been able to think "inside out and backwards" as well or better than the next guy.
Haven't worked at it in a long time (ie., no one is paying me to do it), but I still make the odd master for funky stuff like finned valve covers for my Virago, special stuff for my bobber, etc etc. Haven't sent anything to the foundry in ages either.
Regards,
Users browsing this forum: No registered users and 5 guests
