MidProd 500 Single
Re: MidProd 500 Single
Postby BrianL » Wed Nov 28, 2012 10:32 am
Well, things are looking up!! :D Picked up another lower end and a running TT500! :twisted: So, have most of what I need to get this thing into MidProd without too much worry...Looking at a VM36 or 38 round slide carb, an 18" front wheel and many hours of pleasure...At least the TT solves my tank problems!!! Cheers.
We don't stop ridding cause we get older,
We get older cause we stop ridding...
Special thanks to St-Hubert Machine Shop and Built by Bill
BrianL
Postby Rick Yates » Wed Nov 28, 2012 11:41 am
I have a carb... :mrgreen:
Rick Yates
Postby TimV » Wed Nov 28, 2012 12:36 pm
Hi Brian, what frame do you plan on using? Linc thought the TT frame would be the way to go, as it's much lighter than the SR lump.
Good luck,
Tim
Tim Voyer #840
CMR Suzuki TR750 Replica
CMR-Seeley 350 Replica
1971 P1 CB350
Whatever you do, always give 100%. Unless you're donating blood.
TimV
Postby tintop » Wed Nov 28, 2012 3:45 pm
What width 18, and how many spokes are you looking for??
Postby BrianL » Thu Nov 29, 2012 8:01 am
To Rick: sent you a PM..... :twisted: :twisted: :twisted:
To Tim: the TT frame as it's some 60lbs lighter than the SR frame.... :o
To tintop: How many spokes, hell I don't know, something in 18"x1.85" or even 1.60" with disk brake set up. The SR forks have mounting tangs on both sides....so does not matter which side the disk is on... :wink:
BrianL
Postby BrianL » Mon Dec 03, 2012 3:06 pm
Seem to have tracked down a spoked 18" front rim for the TT. Will talk to the guy tomorrow. Got the kick start routine down pat with the TT. Fires first kick every time!!! :twisted: Will start to look at the pipe this week and probably mount the rear tire. Forks look a little pitted, not too sure about new seals on those rusty tubes :oops: :oops: :oops: . The guy with the front rim has some 35mm forks off some 76' something. We'll see what he wants for 'em! Talk soon.
BrianL
Postby BrianL » Wed Dec 05, 2012 1:58 am
Went to town on the seat foam...plastic seat pan is very light...this is turning out better then I could have hoped....Pictures tomorrow, stay tuned!!! 8)
BrianL
Postby BrianL » Thu Dec 06, 2012 1:04 pm
Wow, got so excited with how the seat turned out that I forgot to take pictures before I ran the pan and foam over to my cover guy...Just have to wait for finished pics. Got the rear tire mounted (just did not to bead!!! :x :x :x ) But it finally did and on she went...Looks nice with the Avon. Got the fly wheel off the build motor, but threads are funky on the lightened fly wheel, so having trouble getting that puppy off. Imaging, 27mm left hand thread, can only clean 'em up best I can and sorta force the puller to start the threads. At $12, a new puller won't be to bad!!! :oops: :oops: :oops: The welded and balanced crank and the Carrillo rod were a trade for some old CB500 stuff I had lying around...With the lightened fly wheel...Should make for an interesting build. (on the cheap)...Cheers.
BrianL
Postby BrianL » Thu Dec 06, 2012 1:09 pm
What a score!!!!!!!!! :D :D :D :D :twisted: Here's a nice classic build from the UK... :twisted:
BrianL
Postby autofobe » Thu Dec 06, 2012 9:25 pm
Things look like the are moving along.Very cool UK build,if that's what you are going for.I think the under tail exhaust is a no no.Better make sure. :D
Brad
autofobe
Postby BrianL » Fri Dec 07, 2012 1:19 am
No undertail exhaust for me!!!! I have enough toxic gases coming from that end as it is... :mrgreen: :mrgreen: :mrgreen:
BrianL
Postby bwaller » Fri Dec 07, 2012 3:17 pm
We'll all try to remember that on the grid next season!
You're making great progress Brian.
Which way'd they go?
bwaller
Postby BrianL » Sat Dec 08, 2012 1:02 am
Well, got the front end mocked up minus the front brake. Fork brace looks good, clip ons are comfy ( :cry: ), and tach looks like a shoe in...Here's some pics...Cheers.
BrianL
Postby BrianL » Sat Dec 08, 2012 1:04 am
More pics....Having fun!!!!! :lol: :D :lol: :) :o :o
BrianL
Postby BrianL » Sat Dec 08, 2012 1:06 am
Not much left in the fit department...Rear sets, caliper, and a pipe (not for smoking) an exhaust...
BrianL
Users browsing this forum: No registered users and 11 guests
