1988 Honda Hawk
This Hawk raced successfully by Jody Pearce 2013/2014, is for sale.
Race ready bike for VRRA Period 4 F3 class
Specifications:
Hyperform rear sub frame
GSX-R u/d forks, set up by Accelerated Technologies
Fox rear shock serviced by Accelerated Technologies
GSX-R front wheel and discs
Factory Pro 4 degree advance rotor
Mega Cycle 174-x8 Cams, degreed to spec.
241-H R/D race springs with titanium caps
Heads ported with .020” shaved off and valves fitted by Gord Bush
Factory Pro Carb kit and Uni Pod air filters
Vacuum fuel pump
ZX 11large capacity radiator
Buell 9000rpm tach
520 chain and sprockets
Alloy Rear sprockets by Rebel Gears 42/43/47/46 + steel 44
Alloy Belly Pan
Extra front and rear wheels, front with rotors
Miscellaneous spares
Dyno test 2013: 64.5 hp with 40lbs torque at 9000rpm (rev limiter)
Asking $3200
Peter Sheppard
psheppardracing@gmail.com
613-210-0889
Specifications:
Vacuum fuel pump
Buell 9000rpm tach
Alloy Belly Pan
Asking $3200
Peter Sheppard
613-210-0889
