Honda RS125s FOR SALE 2005 & 2006 (ex Ben Young)
Honda RS125 2006 – Ex Kev Coughlan / Ben Young - $5000.00
This bike was brought over from the UK in 2007, seconded owners.
Only few modifications done to keep reliability and low maintenance. Full engine was just rebuilt, very few miles on newly refreshed engine.
Specification -
New Crank,
New Clutch,
New Top End,
Cylinder Head Skimmed,
Ports Polished,
Sealed Carbon Fiber Air Box,
Short ratio 1st and 2nd internal gearing,
Detonation counter.
Parts Included all HRC Genuine Parts
Pistons x 2
Piston Rings x 8
Piston Pins x 2
Piston Clips x 6
Small End Bearing x 2
Cylinder Head x 1 (used)
Standard Internal Gearing, 1st & 2nd
Jets & Needles (various sizes)
Gaskets & “O” rings (various)
Wiring Harness x 3
Front Sub Frame x 2
Front rotor (disc) x 1
Bodywork x 1
Paddock Stands x 1 set
Call Scott / Ben on 1 705 888 2759, email – scot-build@hotmail.ca for further info or picture requests.
Honda RS125 2005 Ex KRP/Ben Young - $7000.00
Full kitted RS125. Purchased from multi GP125 British Championship winners KPR. Purchased for $16,500.00 in 2009. When KRP raced the bike in the UK they got 49 BHP. Raced 2009 / 2010 and used on and off between 2011/12.
Full luyten kit, ie, cylinder (plus 1 spare and both just replated), head (plus 1 spare).
38mm Carb,
Custom exhaust,
Olhins Rear Shock,
WP Front Forks,
Brembo Master Cylinder and Calipers,
Short ratio gearbox,
Carbon Fiber Sealed Airbox,
BPS Ignition with Detonation Counter and Datalogger,
A,B,C,D ECU Settings (mapping),
Kit ECU,
Kit Harness,
New top end, i.e, pin, clips, piston, small end bearing,
Brand New Rad,
Brand New Bodywork,
Spare Bodywork,
Jets.
Luyten Cylinder (replated) x 1
Luyten Cylinder Head x 1
Small End Bearing x 3
Piston Pins x 2
Front Sub Frame x 2
Kit Wire Harness x 1
Brembo Front rotor (disc)
Bodywork x 1
Additional Parts for both machines if required
Clutch lever x 3
Brake Lever x 2
Rear Brake Lever x 1
Gear Shifter x 1
Rearsets x 1
Foot pegs x 2
Fairing Bracket (side tube)
Rear Extended Subframe
Handle Bar Tubes x 2
Throttle Cable x 1
Clutch Cable x 1
Front Break line x 1
Radiators x 2 (leak repaired)
NGK plugs x 4
HT cap x 1
Stat cable x 1
Rev Counter (tac) x 2 (one new, one repaired)
Clutch set x 1 (new)
Clutch set x 1 (used but good backup)
DID Chains x 3
Wheels x 1 set
Gearing 35 to 41 / 14 to 17, 3 of each
Seat pads x 2
Front Brake Pads x 3 sets
Tyre Warmers x 1 set
For everything listed above $12,000
Pictures click the link - https://www.facebook.com/photo.php?fbid ... =1&theater
Specification -
New Crank,
New Clutch,
New Top End,
Ports Polished,
Detonation counter.
Pistons x 2
Piston Rings x 8
Piston Pins x 2
Piston Clips x 6
Wiring Harness x 3
Front Sub Frame x 2
Bodywork x 1
38mm Carb,
Custom exhaust,
Olhins Rear Shock,
WP Front Forks,
Kit ECU,
Kit Harness,
Brand New Rad,
Brand New Bodywork,
Spare Bodywork,
Jets.
Piston Pins x 2
Front Sub Frame x 2
Bodywork x 1
Clutch lever x 3
Brake Lever x 2
Gear Shifter x 1
Rearsets x 1
Foot pegs x 2
Throttle Cable x 1
Clutch Cable x 1
NGK plugs x 4
HT cap x 1
Stat cable x 1
DID Chains x 3
Wheels x 1 set
Seat pads x 2
