Kawasaki EX 500
Posting for a friends son.
" the bike is a 1988 ex500r also spare rolling frame.the suspension is fox rear shock and eibach spring the front spring are progressive rate and re valved both were set for 175lbs rider. the engine is stock bore but fresh top end, the piston and rings are new, stage 1 cam and the valves and valve springs were replaced to mach the cam, the engine is also port and polished, the carburators were also cleaned up and jetted for the change in the motor. the frame does have some reinforced stress members added. the only thing missing from those pictures is the silver fairing, and the extra seat. the motor only has an hour or so on it from when we finished the work.
if someone was interested in the whole package and all the extras i would like $2000. i can deliver if not to far away otherwise i will deliver a reasonable distance for the price of gas."
Contact Laurence at : xlthumper@gmail.com
Pictures at:
http://s581.photobucket.com/albums/ss259/rich122/ex500/
Pictures at:
