1974 Z1 Superbike 1982 KZ 750
I'm building a Z1 Superbike and its about 70% done.It will be for sale once I'm finsihed for approx. $6000 would also consider selling as is. $3750
Here's a list of the parts and work already done;
Engine, NOS .25 over custom machined CB 450 pistons with new rings and fresh boring. Head shaved .010" and ported with HD valve springs,Intake seat area bored out for improved flow , cams .420 lift road race cams,degreed.
New Cam Chain
welded 900 crank
Electronic ignition
Frame, chromed,raked and braced
Wheels 18" 3 spoke GPZ 750 3" rear 2.15 front
Swingarm 1983 KZ 750 braced
front end 1982 GPZ 1100 ,38mm
Bodywork, 1976 KZ 900 ,fresh base coat clear coat ,med. metallic blue(GM code 23 maui blue) two tail peices and two tanks
Seat recovered superbike style with light fiberglass seat pan.
Choice of wolf or Hindle exhaust
1982 KZ 750 ,ideal for street or track $2900 race ready (you supply tires) or $2200 as is
can be seen on my website www.teamkz.ca
New Cam Chain
welded 900 crank
Electronic ignition
