Board index VRRA Racing Forum Trading Post - Bikes for sale!
1993 Yamaha TZ250 4DP <<SOLD>>
This section is for bikes only
Postby akipin » Mon Jan 25, 2021 8:05 pm
Sadly I'm selling my 93 TZ250 that I've owned for the last 18 years (2002) $11,800
Pics;
https://photos.app.goo.gl/H9mwhs7jD9KJTbkLA
Cheers,
Andre Kipin #818
andrekipin@gmail.com
akipin
Re: 1993 Yamaha TZ250 4DP
The deets;
-Brand new fairing & tail; just mounted (unused)
-New fender (unmounted)
-Old fairing & tail; tired but useable (was used until last Aug)
-Front (Battle Factory) and rear (Yamaha) stands
-New Zero Gravity tinted windscreen; undrilled and unmounted
-Fresh crank rebuilt last July by Gord Bush; 1 trackday 100km (Aug 2020)
-‘96 leaded cylinders
-‘96 4DP-40 leaded ignition box
-Battle Factory rearsets
-Penske rear shock
-Brembo master cylinder
-Spare wheels w/Brembo full floating front rotors w/fresh Dunlops w/one trackday (100km)
-Rear sprockets 37-41T
-Alternate internal gears
-Spare ‘96 ignition box (4DP-40 leaded)
-(2)Spare cylinders (need replating)
-Spare radiator (very good condition)
-Spare footrests and pegs
-Spare cylinder heads (2)
-6 used pistons (~330 km on each)
-Spare jets
-Used Brembo master cylinder
-External starter tool
-‘96 Turfrey pipes; right pipe good condition (needs paint), left pipe mount modified for ‘93 but needs repair
New Parts
(2) 4DP-116321-02-A0 (pistons)
(2) 4DP-116321-02-D0 (pistons)
(4) 1RK-11611-01 (piston rings)
(2) 137-11633-10 (wrist pins)
(2) 93310-316D5 (small end bearing)
(11) 93450-17129 (wrist pin clips)
(1) 4DP-24500-01 (fuel petcock and gasket)
(2 sets) Dunlopads RDP213 (front brake pads)
(1) 53141-NX5-770 (Honda throttle tube; same as TZ)
(4) NGK R6252K-105 spark plugs
(1) 3YL-16321-01 (clutch/friction plate)
(4) 168-16324-00 (clutch/steel plates)
(1) 3XV-13621-00 (intake manifold gasket)
(1) 3XV-13621-01 (intake manifold gasket)
(1) 3XV-13622-00 (intake manifold gasket)
(1) 90215-21239 (lock washer)
(2) 3XV-13613-01 (MAIN REED)
(2) 2KM-13614-00 (inner reed)
(1) 90280-04051 (crankshaft woodruff key)
(13) base gaskets (various thicknesses)
(1) 99237-00180 (tank sticker)
(2) 99247-00280 (fairing lower sticker)
akipin
Return to Trading Post - Bikes for sale!
