Board index VRRA Racing Forum Club Announcements
Quebec GP
Information, announcements from/for the Executive. Schedule changes,upcoming events. If it's not CLUB business (public domain), it will be deleted!
Quebec GP
Postby Pat Nicholson » Tue Aug 16, 2011 8:26 pm
Hi All, I am working on the Quebec GP entry forms & schedule and will have them up shortly. It is important for you to know that there is a 106dB limit at St Eustache: There is housing around the track and they are serious about the noise limit. They might pull bikes off the track if the sound limit is exceeded.
See details below:
Noise Limit
• Autodrome St-Eustache has a noise limit of 106dB measured 3 feet from the exhaust at 45 degrees at half the maximum RPM. Spot checks will be made throughout the event.
Pat Nicholson
Re: Quebec GP
Postby racerdude413 » Tue Aug 16, 2011 9:35 pm
So the exact same as Shannonville...
http://www.vrra.ca/wp-content/uploads/2 ... -Sha-3.pdf
Noise Limit: Shannonville has a noise limit of 106dB measured 3 feet from the exhaust at 45 degrees at half the maximum RPM. Spot checks will be made throughout the event.
Dominic Aubry
When in doubt, gas it!!!
racerdude413
Re: Quebec GP
Postby Pat Nicholson » Thu Aug 18, 2011 11:04 am
Yes, the sound limits are the same as Shannonville but the difference is that we have not had noisy bikes pulled there (yet). This might change in the future if some continue to ignore the sound limit.
The last time we raced at St Eustace in 2006 there were some obviously noisy bikes fingered for a sound check. It is quite likely that the limit will be enforced by the track this year as they have obviously had to take steps to reduce the sound carried to the surrounding houses, hence the sound berm.
This is just a heads up that open exhausts are unlikely to meet the sound limit and steps should be taken to muffle these bikes. 106dB is not that hard to meet, even for those with early bikes.
Pat Nicholson
Return to Club Announcements
