Board index VRRA Racing Forum Club Announcements
Bulletin Board access
Information, announcements from/for the Executive. Schedule changes,upcoming events. If it's not CLUB business (public domain), it will be deleted!
Re: Bulletin Board access
Postby mccoy » Thu Dec 06, 2018 5:57 pm
Log in to "Series Tracker Online", click on "View/Edit Your User Info", scroll down to "Race Team Information", 4 lines down is the "Team Headquarters" field.
For those who still insist on using a screen name please edit your screen name exactly as it appears on the forum into the “team headquarters” field on your SeriesTracker rider profile. We will be pulling the data weekly starting Dec 1.
I also don't understand why we would enter a screen name in the "Team Headquarters" field. Are you just using this field as a common location for all of those who want to use a screen name?
Postby Velo » Thu Dec 06, 2018 7:33 pm
Thanks Tim , I guess I was in too much of a hurry & didn't look far enough . Cheers, Gary
Velo
Postby Paul&Sharon Bowyer » Fri Dec 07, 2018 12:14 pm
We are now officially "Tracked"
Thanks again, Paul and Sharon
Ashton Bond wrote:The account’s info is on your joint email.
Using too wide a brush usually leaves a mess for someone else to clean up.
Paul&Sharon Bowyer
Postby Ashton Bond » Fri Dec 07, 2018 12:40 pm
mccoy wrote:Log in to "Series Tracker Online", click on "View/Edit Your User Info", scroll down to "Race Team Information", 4 lines down is the "Team Headquarters" field.
That field is exportable data. So when you add the screen name there we can export it with your normal membership data and Peter can then easily match up your screen name to your actual name and email. address
BRS Racing #161
CCS, USCRA, AHRMA, VRRA
Ashton Bond
Postby Velo » Fri Dec 14, 2018 12:42 pm
I've gone through the steps & still no access . When can we expect to have access? Thanks , Gary
Velo
Postby JR » Sun Dec 16, 2018 3:01 pm
Tryed to edit my profile. Will not take my phone number,that it keeps asking for??
JR
Postby Ashton Bond » Sun Dec 16, 2018 4:00 pm
The format must be standard NA: 123-456-7890 You have to type the dashes as well as the numbers. Every required field in ST shows an example format before editing.
BRS Racing #161
Ashton Bond
Postby cbx550 » Sat Dec 29, 2018 6:06 pm
I renewed today and updated my Series Tracker profile.
I was wondering why I couldn't see the members section.
Bruce Uyeda
faster than DNF
cbx550
Postby kirbster » Sat Dec 29, 2018 7:09 pm
All of this is done manually Bruce.
If you are in a hurry- contact Peter Balfour he controls the switchboard!
Kirby Crosby VRRA #252
kirbster
Postby Peter Balfour » Sat Dec 29, 2018 10:30 pm
Bruce, I have updated your account so you should be able to access the members only section.
Postby cbx550 » Sun Dec 30, 2018 10:24 am
Thanks Peter.
faster than DNF
cbx550
Postby scooterboy » Sun Dec 30, 2018 3:07 pm
done
Postby Paul B » Mon Dec 31, 2018 2:58 pm
I am fully paid for the year . :D
Paul B
Return to Club Announcements
