running a starter motor on the xs engine
Postby scooterboy » Fri Aug 03, 2012 5:18 pm
Hi All
Brain picking again....having the right chair and that funky 6 ft long starter shaft Im thinking going with a starter motor is a good idea, just seeing if theres any tricks to know before I attack the project
cheers
Vic n Mel
scooterboy
Re: running a starter motor on the xs engine
Postby tintop » Fri Aug 03, 2012 9:47 pm
my .02, as I'm only running a starter (no kick access).
My experience was you need either a big battery (with total loss), or run an alternator, and small light weight battery. I went with the later (PM alternator & PC310). Also negated any issues with running a Boyer ignition (eg. low voltage), and electronic tach (extra draw). Does add to the wiring complexity though.
Postby scooterboy » Sat Aug 04, 2012 6:25 am
thanks tintop
scooterboy
Postby paul whittaker » Sat Aug 04, 2012 6:34 am
several of the racers use a separate mobile battery or booster pack with cables to turn the start motor from exposed terminals, thus avoiding voltage drop needed for ign. Rollers are another option. Paul.
Users browsing this forum: No registered users and 11 guests
