SPAM
Sun Sep 19, 2010 7:28 pm
by BANDIT
Re: SPAM
Sun Sep 19, 2010 8:39 pm
by paul whittaker
but for tremendous self control, I would have resorted to your approved method. funny thing every time something gets improved it gets more complicated. I use the old front page as it saves me two moves when logging on, when you are on dial up that helps. Quote by Stevenson, "as in all things but especially so in mechanics, the supreme excellence is simplicity". Paul.
Re: SPAM
Sun Sep 19, 2010 10:13 pm
by BANDIT
In laymans terms I believe that would be known as the "K.I.S.S." theorum,
Keep
It
Simple
Stupid"
Re: SPAM
Mon Sep 20, 2010 6:50 am
by paul whittaker
KISS can lead to an attitude of no progress, Gas tank up in the air. where as simplicity can still be used to advance but in a way that does not add extra burden: gas tank goes into the fender where it provides ballast: Honda would add an electric pump, Joe would possibly add a fuel pressure regulator. Super Joe might use a cam lever operated car mechanical pump from a car driven off the suspension, with return line to the gas tank. IMO add a hole in the manifold and use a vacuum pump (no drain on the battery) with smaller float intake jets as in any? snowmoblie. Paul.
Re: SPAM
Mon Sep 20, 2010 7:30 pm
by Malcolm Lake
paul whittaker wrote:I use the old front page as it saves me two moves when logging on, when you are on dial up that helps.
Paul, simply copy and paste
http://www.vrra.ca/board/ to your favorites and with one click you're there.
Mal
