Now in stock, and orders are shipping out!
Pricing:
Quick Shift Controller - US$75
Sensor - US$125 (comes with 2x 80mm rods, 1x 35mm LH/RH adjusting rod, 4x M6-RH nuts, 1x M6-LH nut); specify PUSH or PULL
A complementary product is a rev limiting switch that can be set to different limits. It can be used as a rev limiter (good for FZR600s using FZR400 TCIs ), as a launch controller (push the launch button, pin the throttle WFO, and feather the clutch - the revs will NOT go past your set launch limit until you release the button), as a shift light driver, or whatever your devious mind can envision.
Pricing:
Rev Limiter Solo - US$50 (stand alone unit)
Rev Limiter Dual - US$75 (stand alone unit)
Rev Limiter Plus - US$25 (built into QS controller)
Push Button - US$25 (for use with Launch Controller)
Instead of trying to duplicate and tap in between the ECU connectors, I decided it would be SO much simpler to use the rear brake and side stand switch connectors (not normally used on race bikes!) to access 12v, ground, and the 'safety' input used on Yamaha, Kawasaki, and Honda bikes. Unless these connectors have been cut off, I can offer plug-and-play installations for: CBR600F2/3/4 & CBR900; ZX-6, ZX-7 & ZX-11, EX250/500; FZR400/600/750/1000, YZF600/750/1000, R1/6, TZ125/250.
The Suzukis don't use a safety pin at the TCI to interrupt the spark, but rather have a relay that shuts off the whole works. Mechanical relays are not known for their accuracy for 50-100msec periods, nor their longevity under frequent and rapid cycling. I will provide a solid-state unit that plugs right in, and is tripped by the Quick Shift controller. At this point, I can provide plug'n'play units for all carb'd GSX-R600/750/1000; +US$10 for the extra component.
If your bike has any of these connectors removed, I can either offer a splice-in unit, or a set of matching pigtails to replace the cut-away parts (+US$5 for a set). All splice-in wires and replacement pigtails will be colour-matched for wiring, to make life easier.
For some models, the connector selection is a little confusing, so I may ask you to confirm which switch connector is which style - is it rectangular, is it hockey-rink shaped, is it two bullet connectors ...
So - who wants one?
EDIT - Prices are in USD; shipping is US$15. At today's exchange, a QS (US$75) and sensor (US$125) and shipping (US$15) = US$215 = C$275. My apologies for any confusion.
