Back to Back starting problems
Postby Brian Stevenson » Thu Aug 29, 2024 7:35 am
I had back to backs at CTMP and there is no way on earth that you can get back to the pit, get another bike, change transponder and get back in time to be let out.
The other big problem with CTMP is that there is so much shit between the walls at pit out its not possible to start from there. Maybe they actually need to go to Canadian Tire and spend $8 on a broom. :D
I'm facing the same thing at Shannonville. Can I just by pass the oil check and bring that bike back later to be checked? Its not practical to have the other bike sitting in the hot pit as then I have to drag the generator up there which other people use
The other problem is that the tower doesn't even bother to flag that you started from Pit Lane. Whats with that?
Return to General Discussion
