Vintage Festival results
Postby Brian Stevenson » Wed Aug 21, 2024 9:10 pm
I've posted the results and points from last weekend. If there is a mistake its most likely with side car passengers as all of that has to be typed into a static table manually. We've been through it a couple of time but if there are any passengers on the forum maybe they can just check again.
As always, if you see any issues let me know.
I haven't done the overall points yet as I discovered something strange with Mylaps. If you start from the pit lane, there are some strange things that can happen with your times and laps. The wierd thing is you are scored in the right position. I didn't notice this before but I had to start from the pit lane twice because of back to backs and couldn't understand what was happening.
I don't know if its a problem with Mylaps or with the tower or with both, however Mylaps has all the data they need to fix it. I will call them tomorrow.
I'm 99% sure this will not impact the overall point standings as our points are generated based on finishing position but we'll make sure.
Re: Vintage Festival results
Postby Dave M » Thu Aug 22, 2024 5:36 am
Thanks Brian!
Dave M
Postby Brian Stevenson » Fri Aug 23, 2024 7:51 am
My apologies that the season totals are not up yet.
There are some anomalies in the data that's in Mylaps/Speedhive for Modern Lightweight and P4-F2. People are either missing from the results or they scored when they didn't actually run in a race at all.
Its only for these 2 classes and interestingly enough they ran together, and this goes the whole way back to the heat race at Shannonville.
I just finished a call with Mylaps and they said that basically they are right, its our fault, sort it out yourself... Nice attitude. Its like dealing with Comcast
I'll work with Timothy to get it resolved ASAP. I just don't want to upload part of the results, or have to fix it later, or give someone erroneous season totals where they end up losing places later.
Return to General Discussion
Users browsing this forum: No registered users and 4 guests
